New AMC 360 Installed - couple questions
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
Hi all,
So finally got the 360 finished up and in. She's running good and strong.
Two concerns - let me know your thoughts on these all. Like to bounce around some ideas...
1 - Still running a bit on the hot side. I have a new flex fan, 180 degree thermostat, new cooling hoses and "shouldn't" be anything wrong with the radiator. Now I'm not running a shroud, but never have and never had any problems with the temp... I am running the temp sensor that came in the new intake still, so not positive on accuracy yet. Next to check. Main question - is it normal for a fresh rebuild to run a little hotter than normal during break in? I assume with stuff starting to "clearance" itself out in there and piston rings seating it would be a little more friction than the old tired 304 had... It's running about 220 - 225 degrees F.
2 - At idle, when I advance timing to 12 degrees per the DUI HEI unit instructions, the engine "stumbles" intermittently... Not really a miss at all, but hard to explain. Shakes a second like a miss would, but thermo temp reading confirms at least not a constant miss, and at higher RPM, or increased timing advance it gets better. I think I have it set at 14 degrees advance @ idle. I'm slightly worried this is too much, though I know some high performance engines run much more than that...
Random mentions for both:
I am still running my MC2100 carb on a adapter to the edlebrock 4 barrel performer intake. Too little fuel maybe? Running lean causes additional heat right? Too little fuel at idle may stumble a bit? Haven't done the calculations, but the carb was right (maybe slightly high) for the 304 CFM - probably a bit low for a 360...
Haven't even re-adjusted carb mixture screws yet really. set them about a 1/2 turn richer than I was running them on the 304.
I do have the shroud for the fan / radiator, just needs adjustment for fitment again, and never needed it even while on rubicon on 100 degree + days before...
Let's see what you all think. Questions on set up etc let me know.
Thanks for looking
Thanks for looking
