Steering Steering shaft alignment
- Atlanta, GA
- 1979 CJ5 Renegade 258, t-18 pretty much stock except for a later model aluminum intake manifold and Gronk 2150.
Replaced the TS switch recently. When I put the steering wheel and lock plate back together I oriented the shaft with the mark at 12:00. The lock plate had the same mark and went back in the same way. With the steering wheel back on the wheel is 90 degrees off which is annoying to say the least. Before I go down to the alignment shop I wanted to make sure the orientation marks were correct.
Thanks,
Jim
Thanks,
Jim
