New guy here. Been working on a
CJ7 that sat for 7 years, been going through a lot to get it going. Saw this post on the HEI wires, I just installed the HEI Dist from Summit and was told that I needed the larger wires to make the dist work best, so not sure if stock wires is a good idea. I put the MSD 8.something on and seems to be working great and it did come with the cutter/crimper tool and 1 extra wire for around 100.00 from Summit.
I do have a question on the HEI Dist, What is the best place to get the 12v for it? I was told that I need a 12ga wire to make it work best and the old coil wire is smaller, saw where some use the old coil wire through a starter solenoid, that seems to be a working solution but is it necessary?
Hope this was the right forum for that question
