Heater (Blower Motor) Wiring
musciab
- Tiffin, Ohio
- 1974 CJ 5, 6 cyl 3 speed, AMC 20 Rear, Dana 30 Front
Ok, finally got the rear end finished and need some heat for the winter. I have pulled the heter assy out of my CJ5 and took the motor off and tested it to make sure it worked. I added a pig tail to the only connector on the motor so i dont have to take the housing back out to get it wired up. I also added a ground wire to one of the bolts on the motor and will attach that somewhere.
Now my question....If you look at the pics attached i have a the 3 pronged resistor on my housing and what it looks to be the original connector from the wiring harness. Also i have what it looks to be the original connector for the blower motor switch from the wiring harness. For the resistor connector, there are 4 wires to it and the switch connector also has 4 wires. Where does my motor get tied into???? I have not checked to see if any of the wires h ave power bc my meter is acting up. If someone could explain what wire does what and what wire is supposed to hook up the motor, i would be most greatful. Thanks.
