Custom Cj fenders for Tj flares
Petescj
Member
Lifetime Supporter
PA
Most of you know Im not a fan of high suspension / shackle and or body lifts. Everything is fine in moderation so to speak. Thats why I always tout the Tj fender flare modification for Cjs. This mod really opens up the wheel area for your Cj to accept larger tires without the disadvantage of a higher center of gravity or the danger of snapping longer body mount bolts in off camber / under load situations.
The downfall of using Tj flares is you have to cut your existing fenders and the body lines dont match up well if your not a professional body man. The rear fenderwell isnt a problem but the front fenders can be unsightly.
Enter Jeff Scherb. Youve probably seen me mention his work here before here:
http://www.jeep-cj.com/forums/f49/cj-pick-up-2879/?highlight=gaucho
How about these new fiberglass fenders Jeff has come up with that work on a Cj Grill and follow the line of the Tj flares. If I can get my hands on a set I'll be using them for sure. :cool: Heres a couple pics showing what Jeff has done with a complete fiberglass front clip using a Cj grill for a Tj / Lj
yes please. one question though. can you open the rear wheel wells up to accept the tj rear flares on a CJ5?
Yup. Ive seen them on one CJ5. If I can dig up a pic I'll post it. Not sure if I can remember where I saw it though. :confused:
His work is awesome
Makes the club I use to run around with grill we made look amateur...which it is:D
you mean like this one?
Call it what you want but that is pretty freakin cool. :notworthy: What an interesting idea. How many beers did it take to inspire this creation? :D
His work is awesome
:agree:Killer grill man.:chug:
Thanks guys, I was just a part of it, our club hosts a big "summer bash" every year with a huge bbq and we decided -as pointed out under the influence of many beers- we decided we needed a bigger grill. One of club members donated the CJ and we went to work!
The best part is we heated the frame pulled it in and welded on a tow receiver. You will notice the turn signals are red we made them brake lights. I can't imagine the thought going thru people's heads as they come up on a jeep facing backwards.
