80 CJ5 Rear Axle
80 CJ5 Rear Axle
Super8mm
Bronze Supporter
Grapevine, TX
1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
I am getting ready to order some Moser 1 pc axles and am wanting to verify this is the stock 80 AMC CJ5 rear end?
I know there was a place that had a comparison of the different ones but now I cant find it
There has been a lot of talk lately about rear disc brakes for that axle. Please let us know which set you're going with.
I ordered the TSM's
I would also change out those diff cover bolts in the AMC Model 20 while your at it. Those OEM cover bolts can be a bear to remove. Maybe install some regular hex head bolts.
Also when I installed the Moser 1 Piece Axles on my '79 CJ7 - which I no longer own - I removed the thrust block.
Thanks, I was thinking of changing the gasket too :chug:
