80 CJ5 Rear Axle
Super8mm
- Grapevine, TX
- 1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
No problem. Narrow Track AMC20
There has been a lot of talk lately about rear disc brakes for that axle. Please let us know which set you're going with.
I would also change out those diff cover bolts in the AMC Model 20 while your at it. Those OEM cover bolts can be a bear to remove. Maybe install some regular hex head bolts.
Also when I installed the Moser 1 Piece Axles on my '79 CJ7 - which I no longer own - I removed the thrust block.
