Tranny removal
Tranny removal
weithman5
Illinois
84 cj-7 renegade (original owner)
Sorry if this has been covered but couldn't find. I am removing the tranny from my 84 cj before pulling engine. Is it easier to leave the crossmember and tranny together and separate later or leave the member on the frame . The tub is off so I can get to it from above
i would say pull the trans leave the crossmember.
I always drop the crossmember to get to the driveshaft bolts and shifter bolts because my tub has been in place most of the time
Do you mean the skid-plate??:confused:
Pull the s'plate and then the tranny.
Put support under the engine so it doesn't twist and tear the rad. with the fan blades.
Make sure you disco the POS(+) battery lead.
I use ramps that lift my rear whheels about 12" for clearence to remove the tranny and t'case as a single unit from under the jeep.
Hope you have a tranny jack;)
LG do read the posts? He said the tub is off.
thanks guys.
yes I guess you could call it a skid plate. manuals all referred to it as a cross member.
yes tub is off. I have the engine supported for the time being. I think taking the cross member off first and then backing out the transmission with floor jack may be a little more user friendly
I did read the post-That's why I asked for the clarification of wording used.
My CRS came into the game also. :D
In my defense-I was only on my first cup of coffee. :laugh:
