Misc. Ticking While Starting
JSM
Hi and thanks in advance for any guidance. I'm attaching a sound clip of a very noticeable tick when starting. As soon as it fires up it stops so I assume it's something in the ignition/starter system rather than the engine. I thought it may be something with the starter but have swapped that and no change. I also checked the ring gear while I had the starter off, and it looks good (no ground teeth, etc). It's a bit rough starting/idling at the moment, which you'll also hear in the clip, but that's because it's been sitting and it appears that I likely need to rebuild the carb. I'm trying to figure out the source of the startup tick in the meantime though. I tried digging through other starter related threads but no success so far finding anything similar. Thanks again for any thoughts and help diagnosing.
