The internet is an amazing tool for info, but........
Rescue Diver
Full Time Jeeper
- Kansas City
- 1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
I had another reminder to take everything you read on the net with a grain of salt recently. Shirley just purchased a 2001 Cherokee Limited with only 77,000 miles. It runs great other than it's hard to start. You have to cycle the key several times before cranking it to get it to fire up. I decided that was unacceptable so I took to the net to see if I could find the cause. It turns out that her new Jeep has a very common problem. Either her fuel pressure regulator has a bad drain back valve, or there's a bad o-ring in her fuel pump assembly. This allows the fuel to drain completely out of the fuel rail and fuel line, all the way back into the tank immediately after shutting it off. It should hold at least 25 lbs of pressure at the fuel rail for five minutes after shutting it off, but hers drops to zero lbs withing a couple seconds. The fuel pump as designed only runs for a couple seconds to pressurize the system when the key is first turned on, so it takes two or three cycles of the key to move enough fuel to fill and pressurize the line all the way from the tank to the fuel rail. I've now proven this beyond a shadow of a doubt using a fuel pressure tester and a pair of vice grips to clamp off the hose back at the tank. To find that testing info, I had to wade through countless threads in all kinds of different forums where user after user kept spewing nonsense. One guy said his hard starts were due to a bad O2 sensor when the O2 sensor doesn't have anything to do with the initial start. Another said it was the crank sensor, but if that were true, it would not run smoothly once started. Another guy said it must be leaking injectors, but if that were the case, it would be blowing black smoke when you start it from all the pooled gas in the intake, and it wouldn't take as long to presurize the line because it would still be full all the way to the rail since the injectors are higher than the fuel line and gas tank. Not one of these guys ever reported back that thier problem was fixed after replacing whatever part they said was the problem. These guys would have you replacing good parts repeatedly, in a blind attempt at fixing it before finding the true cause.
Diagnosing a problem is like putting a puzzle together. It's even harder when you're getting your info on the net, because that's like putting a puzzle together where you have pieces from 10 other unrelated puzzles mixed in! You have to sort through all the pieces to find only the ones that fit your exact same circumstances, make sure they're legit, and then put them together. It's really frustrating to constantly read posts where a guy comes off as the ultimate authority on something he's never had his own hands on because he read someone on some site saying it's so.
Do your homework. Remember that anything you read might not be accurate, or it might not fit your exact problem. Trust factory info and service bulletins more than Joe Schmoe on the net(myself included). Get the right test equipment. O'Reilly and others loan lots of really good tools for free with a deposit, if you don't want to buy them. And last but not least, look for ways to isolate the problem and eliminate other possibilities before just replacing parts.
Have a nice day!
Have a nice day!
