Separating floor pan from rocker
82Laredo
- Wake Forest, NC
- 1982 CJ7 Laredo - 4.2L, T5, factory 3.30's
1993 Z28 M6 - bolt-ons, cam, s-trim w/alky = 488rwhp
I'm replacing the front floor pans on my CJ7 and this is my first attempt at a "body work" kind of job. The drivers side has rot all the way to the rocker so I'm going to have to separate it from the rocker. I'm assuming they are spot welded together at the lip that folds down from the floor pan and meets the rocker. The issue is I don't see any spot welds....
Are they spot welded together and if so what is the best way to find each weld to drill out? I've gotten good at drilling spot welds and using the air hammer to "pop" them but looking for some advise at finding them. Thanks for the help
