Reverse light not lighting up (CJ7 1977)
Rdavison39
- Oakville Ontario
- 1977 CJ7. 304 H. 52,000 original miles.
2010 Wrangler 2Dr
Okay - i guess i don't understand electricity. Trying to get the reverse lights working.
1. When i check voltage on the reverse light socket across the middle (+) and the metal socket that secures the bulb it reads 11.97 V (DC).
2. When i put the bulb in it does not light up
3. The parking lights, brake lights, and signal on the socket below work fine. When i check voltage on these lights is 12.35V (DC).
4. Hoping it was the bulb(s) i tested them out by connecting wire directly to the battery. All the bulbs worked fine.
So would it be that 11.97 V isn't enough power the bulb. Otherwise I just don't get why the bulb wouldn't light.
BTW - it happens in both RHS and LHS tail lights so i'm thinking i fundamentally am missing something.
