Rear main seal crankshaft issue/ need advice on next step
TPS
Ok so I own a 1974 CJ5 that is for the most part in great condition. It was restored in 2001 by a PO and after restoration and some use it did some aging in a barn. Over the past couple years I have replaced a lot of the wearable items and gave it some TLC to get it back in reliable shape. Engine runs great, new suspension/starter/alternator/plugs/filters/valve cover gasket etc and to top it off it's rust free with a solid paint job. I really love this jeep and I have tried to fix anything and everything if it needed attention and this is where my problem lies. When I bought the jeep it had a rear main seal leak. I have now replaced the main seal 5 times and after learning a little more each time I have discovered my issue. The crankshaft should have knurling or helix engraved on it where it rides up against the seal that slings the oil back away from the seal. The problem is mine doesn't, it's as smooth as well you know. After finally figuring this out through all my failed attempts and research, my question is where do I go from here? I've ran out of rescources locally and figured I would turn to the knowledgeable folks here on this forum. If anyone has tackled this issue before or has suggestions I would appreciate anything you are willing to offer! Thanks
