Engine quick help needed please
Manic Mechanic
Full Time Jeeper
- Thurmont MD
- 85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
im rebuilding my 258. long story short my new block is a 75-79 my old one and head is 81-85 i know the bolts on the new block are 1/2" where the old one is 7/16". is there any other differences i need to know before i call my machine shop and just have them drill out the head to accept the larger bolts. or will there be interference issues and or running problems by using a newer new head on an older block. has anyone else had this problem. i assume that all 4.2 are basically the same minus emissions-related equipment. even more so since i see numerous post talking about putting 4.0 heads on a 4.2 so it cant be that drastically different unless im completely mistaken.
thanks in advance for the help and replys
