Build Thread Project Scrambled - The Diesel Powered CJ-9?
Greetings, I have just planted the first seed of my new off road build. The last one was a Toyota 4Runner on tons but now I'm moving back to the Jeep side of the equation. I needed a place to document the build so here I am.
******************** WARNING! ***********************
If you cringe when sheet metal gets cut up, frames get stretched, engines swapped or generally nothing kept stock in a Jeep then be warned this thread is not for you! There will be carnage, parts will fly, but in the end it will be beautiful.
********************* END WARNING ********************
The Plan for this build...
My last off-road rig build was a purpose built rock crawler truggy with full custom tube work based on a 2002 Toyota 4Runner. First time I had ever gone that extreme with a build. The only thing I regretted with the build is not making it streetable.
This time I want a super capable off-road rig capable of hitting the hardest most gnarly trails in the US but still have the ability to take to the highway comfortably and safely at 65 MPH, AND it has to be a Jeep CJ.
The Jeep:
I am starting with a 1986 Jeep CJ7, mostly stock. I got it FREE!!! Free is my favorite kind of vehicle (and also my favorite flavor of beer)!
The Story Behind the Build:
A few years ago a guy I knew was cleaning up his shop and had a bunch of good auto parts and some guns and he said I could take them free if I just came and removed them. A year or so later I traded the guns for a beautiful 1967 F250 with a 390 FE Big Block. California truck so no rust anywhere except the pans. Only problem with the truck was it had no title (common in Georgia and Alabama). I held onto that truck for about a year until someone offered to trade me this titled Jeep and all these Jeep parts for it. I said SOLD! I owned a 1980 CJ-7 back in college and was really looking forward to building a new Jeep.
I sold most of the stock parts to help pay for the build. Dana 44 rear axle, Dana 30 front, seats, wheels/tires, etc. A lot of parts will come from my previous build, like the axles, links and heim joints for sure. I was even planning on using the awesome and reliable Toyota 5VZFE 3.4 V6 out of that build too, then I decided to go Diesel instead. I also figured I also might anger Jeep traditionalists with a Toyota engine in a Jeep (but ask me if I really care).
The FREE Jeep!
Nice dash in good condition.
Sadly the tub was too far gone all over.
The donor (Previous build)
The Jeep:
- 1986 CJ7 Frame (will be stretched)
- 1987 YJ Tub (will be stretched and modified)
- Mercedes OM617.A 5 Cyl Turbo Diesel. Built with a UK spec 7.7mm M injection Pump (more more horse powers and torques), converted to serpentine belt and H.O. Alt and Trail Gear PS pump to run full hydro steering (got to steer those 40" tires easily).
- Muncie SM465 4 speed manual with granny (6.55:1) low 1st gear.
- DIY NP231 geared underdrive box(s) for triple sticks (I may stack two together meaning the transfer case will have more gearing options than the trans and a final drive crawl ratio of 1035:1 in first gear.)
- Dana 400 with aftermarket billet case built for driver drop and low 4:1 gears.
- Ford Dana 60 Snofighter front axle 3-linked with 5.38 gears and a selectable locker
- GM 14 Bolt rear axle 4 linked with 5.38 gears and either a lunchbox locker or selectable
- 40 x 13.5 R17 Pro Comp MT2s
- Wheels TBD - But will be forged bead locks.
The FREE Jeep!
