Opinions/Options on Clutch Linkage Redesign
Cazenave26
- Raleigh, NC
- 1982 Jeep CJ-7, 4.2 I6 with Dana 300 TC and the Dana 30 in front and AMC20 in back.
Based upon year's of experience I know many of us with the mechanical clutch linkage have enjoyed tremendous reliability of the bell crank design that fails in just about every conceivable situation: Turning, turning at speed, chassis flexed, chassis not flexed, in town, on the highway, in low gear, in high gear, in 2wd, in 4wd. Most folks become experts and throwing the thing together again. I for many years carried a complete set of parts in the Jeep. Heim joint upgrades still don't fix the bell crank and a hydraulic conversion trades a certain mechanical failure with almost equally certain hydraulic failure, which can't be easily reassembled.
I found a guy that had modified the bell crank as I had built and show in the attached image. The redesign eliminated the pin for a machined shaft that bolts through the brackets and goes through the bell crank. Unfortunately, the flexing of the frame binds this system resulting in the entire unit rotating on the ends, not the bell crank around the shaft. I need to try something else. I'm okay with rotation on the end, but I'm not sure bearing mounted where the pins used to be for a rotating shaft to pass through, but frame flexing is an issue. I could replace the pins with Heim joints for the shaft to pass through, but they're not designed to have something rotating inside of them. I guess I could put Teflon bushings on the shafts passing through the Heim joints. It's all in the image. Anyone have any other ideas?
