Looking for 1969 CJ wire diagram
Guys I am working on a 1969 CJ5. I need the wire diagram to trace down the brake light circuit. I know I should just buy a service manual but the Jeep doesn't belong to me, I am helping a friend with it, so I was hoping someone might be able to upload or have a link to one. I have searched through lots of posts on here and have found several wire diagrams for older and several for newer but not for a late 60's.
So far I have headlights, running lights and blinkers all working but no brake lights. I have replaced BOTH brake line pressure switches but same result (only found the one down on the framerail by the MC at first then kept searching and found another up on the frame rail just behind the radiator on the drivers side). I ASSUME I have a good enough ground at the rear light housing since the tail and blinkers both work but I will check out that ground.
From looking at other year wire diagrams, it looks like the brake light circuit ties into the headlight switch and the ignition switch. I haven't been able to find those exact connections yet though on this Jeep.
