Key release mechanism
Trevor Heath
Hi all,
I've just purchased a 1983 CJ7 4.2L T5 300. It had not run in ten years.
We've had it for two weeks and it now runs, turns and stops - still a lot to do though.
As part of the work through, I decided to change the ignition switch, steering lock and turn signal switch as all three had faults.
With all the new parts installed, everything works except the key cannot now be removed. (The fault was there before but the lock/key was so worn the key fell out)
I've pulled the steering column from the vehicle, it is on the bench and concluded (possibly incorrectly) that the issue is the key release lever. It is frozen in place.
The issue is how do I remove the lower shroud to inspect and repair the key release mechanism?
Thanks in advance for any advice.
Trevor
Trevor
