How much is too much
Colo Dean
- Greeley Co
- 74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
Bondo that is....
Got the son working on sanding down the passenger side of his CJ5 and on the rear quarter there were a couple spots that had cracks like someone had used too much bondo. Sanded down the area and found more cracked spots.
It must have had a rear marker light at one point as this was filled with bondo. The hole above was rusted out where the support piece is mounted behind, to the right I think it is nails that were bondo'd in place to fill another hole.(it looks to be a pre-made oval cut in there, anyone have an idea if something originally went there or if this was possibly a patch piece the PO used that had a hole in it?) It looks like it was caved in and they fixed it with a gallon of mud. Hard to see in the photo but the spot above the nails is almost 1/4" deep. Hoping to find enough metal left we can cut in a new piece without having to form the rear curve or wheel opening. Gotta love the way some people fix things.
