Engine Help with fuel issue and line
Brad88yj
I recently purchased a 1983 CJ7 with a 4.2L the motor was in pieces in the rear. I have gotten to the point it runs. The previous owner did a nutter bypass and installed a HEI distributor and 2 barrel carb without the electronics in the rear. The issue I am having is I believe the carburetor is getting to much fuel. It idles fine drives good but when I turn the engine off there's still a steady drip of fuel dumping into the carb. If you look at the picture attached I didnt know what to do with these two ports or vacuum connectors. I just capped them. Any suggestions would be greatly appreciated.
