Hei and coil issue
Hei and coil issue
grnmtn
north alabama
85 CJ7 258 I6, auto, dana 300
:confused::confused: I have am been running the Team Rush with the stock coil. I switched to a Ford e-core coil and the Jeep will run for about 30 seconds and turn off and then restart moments later. I figure the module is getting hot and shutting down. I swapped in a "stealth hei" module with the e-core coil and it now runs about 15 minutes before turning itself off. Any ideas
The Ford E-coil should not have been the cause of your issue. Is it possible that the icm was on its way out before the changeover? Is the stealth icm getting hot also? One thing that can kill an icm is a poor ground.
What is the best way to ground the Icm? Can I splice into the harness/plug and run a wire to the battery post? I put a heat sink on the stealth icm and it's not too hot to touch.
The oem distributor harness/icm is grounded thru the distributor which is not a solid connection, as it is bolted down, from there it makes its way to the battery negative wire on the block. I would suggest as close as you can get to a direct connection to the battery negative terminal as you can get. As far as grounding the Stealth ICM goes, It is grounded at the hold down bolt next to terminal "C", which should have a black wire. I do not think you can install too big of a heat sink either. If it does shut off like you say, the heat could have destroyed the icm also.
