Body Fiberglass Cowl Repair
JMark
- Montclair
- '84 CJ-7, 258, Sniper EFI, AX15, Dana 300 HD Outputs Twin Stick 4:1, York OBA, D60, D44 Locked F&R
Did some damage this past weekend (clipped a tree with my windshield frame, didn't kill the frame) And put a hairline crack across my cowl right where it turns up to the vertical where the windshield is.
I ground out a couple spots to check the extent of the damage, it's a thin hairline crack. What is going to be the best way to fix this? i'm thinking sand things down and v-gouge the crack, then lay in chop strand mat and resin in a few layers, then sand flush and repaint.
