Easy Mechanical Temp Gauge
JeffP
Peoria, AZ
'75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! ‘53/‘54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
I’ve heard many Jeep owners either ask or complain about connecting a mechanical water temp gauge... the typical sensor probe won’t fit.
The simple solution is a brass fitting and pipe nipple available at Ace Hardware.
The first is a Bell Reducer, 1/2” FIP / 3/8” FIP. Lasco Brand #17-9281 34FD. The second part is a 3/8” short brass nipple. Lasco Brand #17-9403 36DL. And of course some teflon thread sealing tape.
On a 304/360 V8 locate the vacuum tee behind the thermostat housing. Remove it, screw in the nipple. Then attach the bell reducer to the nipple. Your aftermarket mechanical gauge will now screw right in.
On the straight 6, such as the 258, the vacuum tee is located on the driver’s side of the block halfway between the oil pan and intake / exhaust manifolds. The same proceedure applies.
Hope this helps!
Lol I haven’t ever thought of using a bell reducer to fit a temp probe in before, good tip
