Dash lighting not working
So, I have the dash dropped out of the Jeep, everything is unhooked. After going through and sorting the wiring disaster, I tried to check all the lights, as I'm going to do an LED upgrade. Unfortunately, I can't get the dash lights to work.
When I say I can't get them to work;
turn signals both work, inside the speedo and rear
brake lights and reverse lights work in the rear
headlights, sidemarkers, etc all work
all fuses in good shape
There is one ground that seems to be unhooked, by the lighting. It looks like it slips over the ground screw on the backside of the dash. Regardless, I grounded it with a spare jumper, and it made no difference.
I am thinking maybe the potentiometer in the lighting switch is bad. Is there a way to really test this? I have looked at the wiring diagram but I can't seem to figure out how to jumper it.
If all else fails, can someone halfway direct me on how to splice the lights to the sidemarkers/running lights? I'm doing the LED replacement which will make the "dimmer" virtually useless anyways. I know where the mid/running light wire is, I'm just not sure which wire I'd splice that to.
Any .02 is welcome.
Any .02 is welcome.
