Dana 300 shift rail seal cover
mike270
Moses Lake, Wa
'84 CJ7 6.0 LQ9, 4L60-E, Dana300, Full size Dana 44 front, Full size Chevy 14 bolt rear
Can someone tell me what this dana 300 part is called? And also where I can find one. All the exploded view diagrams I've looked at either don't have it at all or show it but don't give a name or part number so makes me wonder how important it even is. It covers the shift rail seals. My 300 is currently installed without it. Any advice would be welcomed.
It also provides some alignment for the single shifter. There is another tab which is missing on you broken one. If you have or going to twin stick the TC, that part isn't needed.
Shown with the shift lever and linkage.
Jeep p/n 5360065
Transfer Case Shifting Lever Link
Will be hard to find.
Jeep p/n 5360065
Hagar, what is the part number for the bushings 18.180 6b? Mine are shot, probably are just as had to find as the bracket.
5360135
Should be readily available.
Google " Dana 300 shift lever bushing"
Thanks much. I am using a twin stick cable shifter.
