Custom Axe & Shovel rack
Looks good. Looks like you used 1" thin wall square tubing, mounted it across the roll bar legs with U-bolts, and used some sort of rubber clamping thing to hold the shovel and axe.
Where did you get the rubber clamping things?
Have you seen signs of too much stress on the tubing or mounts caused by the weight of the axe and shovel twisting around as they get shaken while driving?
i mounted my rack on the passenger side wheel weel, but i have a CJ7 so it's slightly longer. i used clamps meant for use on an atv. they have securing straps and seem to work well.
as anyone considered using surplus military pioneering tool racks? they make 2 versions one is a standard unit that fits just about anything that you can bolt it to. the 2nd one was designed to fit under the rear of the HUMVEE and is light weight and hinged.They range between $35.00 for the standard, up to $100.00 for the HUMVEE version.
