Crimping tool
Crimping tool
Dan77CJ7
Denver,303Local
76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
What crimping tool are you guys using for your battery cables. Im going to buy one but looking for some pros and cons. Thanks
If you want a good one find a Snap-On truck.
From what I have seen in larger wire crimping tools they can get pricey, especially as much as they are needed for a CJ. I just get by with a good set of wire cutters to compress the terminal and fill the remaining space in with solder heated with a small torch. Then cover with heat shrink tube.
go to a welding supply they should have one you hit with a hammer. they are less than $30.
