Clutch/pilot bearing
So, I have a 1980 CJ5 4 cyl with the sr4 trans. I'm currently in the middle of installing a new clutch kit and I've ran into an issue. The new pilot bearing and the old one do not match. But, I'm not sure the old one is even correct. I bought this jeep with a clutch issue, and once I got home began to install the new clutch. The old pilot bearing that came out has a bigger o. d. And I. D. The I. D. Of the old one is too big for the trans shaft which is why I don't think it's correct. The new bearing I. D. Fits the shaft as it should, but the o. d. Is to small to replace the old one. It's almost as if I need the 2 combined (o. D. Of the old one, I. D. Of the new one) my question would be, does anyone know for sure what bearing is correct? I'm going to include a picture of the 2 bearings. And no, the smaller one doesn't fit inside the larger one.
