best way to fix this scrambler frame WITHOUT getting a new one
raser13
- festus,MO
- 1977 CJ-5 '83 amc 258 straight six, motorcraft 2100 carb ,inline fuel pump, 1000 cca battery ,T-175 tranny,
hey guys, i just became the proud owner of an 82 CJ8/scrambler. the worst off part of this rig is the frame. basically from right above the rear axle all the way to the back bumper is pretty much swiss cheese. i know that the scrambler frames and scramblers in general are getting pretty rare. so finding another frame to chop up and weld is pretty much out. or getting one in good shape will cost more than i paid for the whole thing. so again pretty much out.
so i was wondering if the back section of a CJ7 would be a direct match up directly so i can this off and weld a new section in? or some other frame? or is there a good way to replace the sections with welding in fresh metal? or can i just chop up another cj frame in sections and weld them back together to make the shape of the existing frame? i'm on a pretty meager budget. but i know when it comes to the frame it needs to be done right. so if i can do it right cheaper right great. but if i need to save and spend more to do it right then that's what i need to do. here's the pics so you can advise me better.
first, up this section is just forward of the rear axle on the passenger side.
second, is the cross member between the axle and the back bumper
third, is a shot of the AMC20 back axle. and a long shot of the cross member just before the axle.
forth up,is the real nastyness. it's the drivers side frame bar behind the rear axle.
fith, is the pass. side frame bar just to the rear of the axle.
sixth, is a patch that some one already did to the outside of the passenger frame bar. again right behind the axle.
seventh in line, is the remains of the body bushing and attachment points on the drives side at the back bumper
eighth up, is a wider shot of that back cross member behind the axle
ninth, is another previous patch. this time drivers side
i know it's really rough. i got a steal on this rig. that allows for a little more wiggle room on repairs. i see this as the worst so this is the starting point. that way i know what i have left to work with once i get done. i know i could just slap some thick steel on there like one of the POs did. but my kids going to ride in this rig so it needs to be done well. best scenario is one of you will tell me that there is another jeep frame that will match up to that section exactly and i can just cut off the bad parts and weld on the new. but i'm not holding my breath. worst case is that i would have to find another scrambler frame some where and pay the made out of gold price that some one would want for the thing
so hit me with your info, suggestions(scrapping it is not one), or concerns. any info is good info. if you need better pics of any area just ask. might take to the weekend to get to them but i will get them. thanks for taking the time to look/respond.
