Basic electrical wiring 101
TeamRush
The thing that scares most people are 'Wiring Diagrams',
All those squiggly, densely packed lines in one place is intimidating,
And depending on if it's a DIAGRAM or SCHEMATIC the stuff you are seeing might not make any sense!
This should help clear some things up...
Diagrams are different than 'Schematics'.
FIRST THINGS FIRST!
If you have a diagram that is small, hard to read, like the diagrams in EVERY service manual you have ever seen,
SIMPLY SCAN THEM AND BLOW THEM UP!
If you scan at high resolution, they will print fine at a larger size.
SIMPLY SECTION THE DIAGRAM/SCHMATIC INTO SMALLER 'BITES'...
When you are doing front lights, there is no sense in having anything showing past the fire wall bulk head connector, so JUST the front end,
If you are working on tail lights, you don't need anything but the back end.
SMALL BITES BLOWN UP TO A READABLE SIZE.
COLORS!
MOST EVERY DIAGRAM HAS THE COLOR CODING OF THE WIRE, AND THE GAUGE SIZE. Simpy use your picture editor to trace in the correct color,
Or get yourself some colored pencils and trace the lines in the correct color.
This makes finding the ACTUAL wire in the harness you are looking for MUCH EASIER when you already know the color and size, or if you have a wire you want to identify, color and size will help you find it on the diagram/schematic!
'DIAGRAMS' are basic drawings to show you where things hook up and where they go.
A 'SCHEMATIC' is a very precise, very technical representation of the electrical circuits, and may, or may not show you were the wiring ACTUALLY GOES, just what the electrical current is supposed to do and what electrical components are in the system...
The biggest issues people have with Schematics is, they ignore the hard parts of any electrical component, it simply doesn't exist if it's not carrying current.
Starters and Alternators look like coils of wire, connection points, ect., NOT starters and alternators...
A 'SCHEMATIC' makes absolutely NO SENSE to anyone that isn't trained in electrical engineering,
So you won't find 'Schematics' on my sites, I don't use them.
Something I wrote a while back, don't know if it will help or I'll have to do it again from scratch...
The closest thing you will come to a 'Schematic' is a factory wiring diagram...
And they are confusing enough to drive any one crazy!
So lets start there...
*IF*...
You look the wiring diagram over really good, you will find 4 pieces of information for every electrical circuit in the vehicle....
1. Wire Ga. Size.
2. Factory Wire Number In The Harness.
3. Where It Originates From.
4. Where It Terminates.
5. Most Wiring Diagrams Give Color Coding information, but not all.
NOW! THIS LOOKS LIKE A BIG OLD MESS!... BUT IT'S NOT...
IF YOU SCAN IT, COLOR CODE IT WITH THE WIRING COLORS YOU CAN FIND LOCALLY,
IT WILL LOOK SOMETHING LIKE THIS...
Makes a LOT more sense this way, and once you scan it, you can even add color banding, from heat shrink or zip ties, and you can change the wire gauge sizes to what you use, ect.
HERE IS THE SAME WIRING TRACE THROUGH THE FIRE WALL BULK HEAD CONNECTOR...
Color code the wires you are working with, trace them by number or color,
Then 'Clip' out the rest of what you ARE NOT working on that day...
This keeps the project 'Manageable' and you don't get overrun and feeling overwhelmed.
FUNCTION DIAGRAMS.
The battery & light bulb diagrams above are 'Function Diagrams'...
Side marker function is a HUGE source of questions, and there is no way to explain it without a FUNCTION DIAGRAM, and somone on the other end that can understand that FUNCTION DIAGRAM...
FUNCTION DIAGRAMS will show power flow, work done, ect. instead of specific wiring colors.
THIS IS ANOTHER EXAMPLE OF A 'FUNCTION DIAGRAM'...
'QUIRKS' IN JEEP WIRING DIAGRAMS.
This is the Brake Warning Lamp Wiring, and the Ignition Switch Connector is UNLABELED in the factory diagrams,
The connection between lines at the COMBINATION SWITCH are NOT shown as connecting...
Why they ran two wires is beyond me, the GM Ignition Switch 'Test Ground' could have been up in the harness behind the fire wall... (See Dash Cluster Diagram 2 Images Up, Corrected Version)
84-86 WIRING DIAGRAMS...
84-86 Wiring Diagrams are CRAZY! You guys have your work cut out for you!
GROUNDS.
WIRING DIAGRAM TEMPLATES.
These are links to basic wiring templates you can down load and practice on.
Open the links, Right Click 'Copy Image',
Then open with MS Paint on your computer.
In MS Paint, Left side tool bar,
Click the top right tool (a little box)
Then Right Click in the main window and click 'Paste',
Draw in your own wiring, components, ect.
I've left you some Breakers, Fuses, Relays, Ect. In the center of the template you can copy if you need them,
Clip out of you don't...
LINK: BASIC EXTERIOR LIGHTING TEMPLATE,
EXAMPLE: HEADLIGHTS ON RELAYS.
EXAMPLE: OFF ROAD LIGHTS ON RELAYS.
LINK: BASIC STARTING, CHARGING, IGNITION TEMPLATE,
EXAMPLE: IGNITION, CHARGING, STARTING CIRCUITS,
SOME CJ SPECIFIC WIRING DIAGRAMS YOU MIGHT NEED, AND CAN DOWN LOAD AND PRACTICE SORTING OUT, BLOWING UP, COLORING IN OR JUST EDUCATING YOURSELF.
SPECIFIC AMC YEAR WIRING DIAGRAMS, HIGH RESOLUTION SCANS.
I'm Putting These Up Here So When YOU Look For Them, YOU Don't Have To Root Through The Entire Thread...
1972-73 LINKS
1972-73 Jeeps will have an 'Amps' light in the cluster and no 'Volt' gauge,
They also DO NOT have brake failure warning lights.
72-73 Engine Diagram
72-73 Chassis Diagram
1974 Though 86 have Volt Gauges on the dash, Brake Failure Warning Lights,
And will NOT have an 'Amps' light in the cluster.
1974-75 LINKS.
1974-75 Used a Delco SI alternator on I-6 engines, Motorola on V-8 engines,
Prestolite Ignition on I-6 and V-8 engines.
74-75 Engine Diagram
74-75 Key Page 1
74-75 Chassis Diagram
74-75 Key Page 2
1976-77 LINKS.
1976-77 Models use a Delco SI Alternator on I-6 engines, Motorcraft 'Square Ear' on V-8 engines,
76-77 Engine Diagram
76-77 Key Page 1
76-77 Chassis Diagram
76-77 Key Page 2
1978 LINKS.
Delco SI Alternator on all engines, Ignition was Jeep/Motorcraft on all I-6 and V-8 engines.
78 Engine Diagram
78 Key Page 1
78 Chassis Diagram
78 Key Page 2
1979 LINKS.
79 Engine Diagram
79 Key Page 1
79 Chassis Diagram
79 Key Page 2
1980-83 LINKS.
80-83 Engine Diagram
80-83 Chassis Diagram
80-83 Tail Lights & Miscellaneous.
1984-86 LINKS. (SCANNING)
Delco SI Alternator on all engines, Ignition was Jeep/Motorcraft on all I-6 engines with a Engine Control Computer. No V-8 engines offered from the factory 84-86.
84-86 Page 1.
84-86 Page 2.
84-86 Page 3.
84-86 Page 4.
FIRST THINGS FIRST!
COLORS!
*IF*...
1. Wire Ga. Size.
FUNCTION DIAGRAMS.
GROUNDS.
1972-73 LINKS
1974-75 LINKS.
74-75 Key Page 1
74-75 Key Page 2
1976-77 LINKS.
76-77 Key Page 1
76-77 Key Page 2
1978 LINKS.
78 Engine Diagram
78 Key Page 1
78 Chassis Diagram
78 Key Page 2
1979 LINKS.
79 Engine Diagram
79 Key Page 1
79 Chassis Diagram
79 Key Page 2
1980-83 LINKS.
84-86 Page 1.
84-86 Page 2.
84-86 Page 3.
84-86 Page 4.
