Diff axle question
DB80CJ5
- Drummonds, TN, USA
- 1980 CJ5, with a 68 AMC 343, T5 4spd trans, Dana 300 T-case (??) Dana 30 front diff, Dana 44 rear. 4 in suspension lift with 35 in tires.
I have an 80 CJ5, 20 years ago when I did a frame-off restoration on it, I took out the AMC20 rear diff and put in a Dana 44 from I think was out of a 76 CJ. I found an old post on here where a gentleman listed all the axle widths through the years and referenced a Jeepteck website. According to the website, all narrow tracks should be the same at 50.5 inches wheel to wheel. Along with the AMC20 rear-end. With the wide track starting in 81. However, I know my AMC20 was wider than the Dana 44 I installed because I had to run spacers to keep the same wheel-to-wheel width. I also have a Dana 44 out of a 76 mail jeep, that is the same width as the one I have currently in my jeep. I could swear back when I was building my CJ that starting around 73 every few years the width got wider by a couple of inches and I could only go back to a diff out of a 78 to match the width of my 80 Jeep? Am I nuts? I'm old so it's very possible. I need to replace the diff I currently have and I don't want to run spacers anymore so was trying to find a Dana 44 with the correct width, but I'm still not sure what years will work in my Jeep. I would not mind going to a wide track as 70 mph in my CJ is a bit hair raising. I have found a 76 scout I'm thinking about using for axle swap, but I have read the front end doesn't fit well? Has anyone done this swap? What issues did you run into? Any help would be greatly appreciated.
