ALl the infromation out there is confusing me
thardy32541
1985 CJ7 with a 258 webberized. Three speed auto. Had finally decided I am going to lift it 4 inches with a ProComp lift. 15x10 MT classic wheels with 33x12.50 Pro Comp extreme MT's. What gears? well I discovered that I have 2.73's in a AMC20. That sucks. Contacted 4wd.com to get a all around quote. Well, guess what, you have to replace the carrier since the 2.73 is specific and cannot change gears. After chnaging the gears in the front to match the rear, I will end up with 1500.00 in parts alone and still a AMC20. I was at the point of pulling the trigger, ordering the parts until I slept on it. I have a client that has a 2005 Rubicon TJ he has converted into a serioud crawer. I remembered he told be he was upgrading to a 60. Lucky me, he is willing to trade some elbow grease for his Dana 44 with locker. He also is giving me the upgraded inner and outer cromally axles from the front. His ratio is a 4.88 which means I will have to replace the gears in the front on mine. I will now have all around disc brakes.
My question is this, Is this a direct swap and easy to do since I will be performing this while installing the lift?
