4x4 manual hubs c clip won't fit on now!
powdertwoplanker
- Boulder
- 1985 CJ-7. guess it has an 89 straight 6 with weber crab. Auto trans and transfer case (not sure what but stock [maybe 300 on the transfer]) open diffs. Hard top and doors
Hi all, so I have a question for you all that have either done your wheel bearings and/or ball joints. Have you ever had a problem with getting the c clip back on after you did all the work?
Basically i just did the ball joints an since the hubs were off thought it would be good to do the wheel bearings too. I did the spindle bearing also. So now I'm get it all back together an i go to put the c clip on to hold the manual 4x4 hub an the axle is not out far enough or the hub not back far enough. What did i do wrong? Could it be that the inner wheel bearing is not seated fully, or possible something with the spindle? I don't need much.
Does any one know what size bolt will screw in to the axle? Thought if i could get a bolt in there i might be able pull the axle out enough to get the c clip on.
Called it a night so I'll be back at it in the morning maybe then it will all fit . If not i guess I'll be taking it all apart again
Scott
Scott
