Misc. 1981 CJ7 trans mount not aligning with skid plate holes
laredo81
Northern Virginia
'81 CJ7 Laredo, 258, SR4, D300, AMC20, D30
Hello Jeepers,
Curious if anyone has some insights to an issue I'm having with a transmission mount. 1981 CJ7, AMC 258 motor, Borg-Warner SR4 transmission, Dana 300 transfer case. I installed the motor last night and mated it to the bell housing and it really took some finagling to get things to line up and eventually secure all the motor mounts, etc. I've been having issues with the skid plate aligning with the frame holes, probably since the dimensions all change a bit under weight/load. Got the skid plate back on, but had t undo the transmission mount to do so. Now when I try to attach the mount, the torque pin aligns fine, but the actual transmission mount holes look like this:
https://www.leokahng.com/BLOG/1981-Jeep-CJ-Laredo-Restoration-Project/1981-CJ7-Restoration-20210918
This the arrangement:
Aftermarket motor and mounts, but the block is a Jeep 258, mounts from M.O.R.E.
The transmission mount is also aftermarket from M.O.R.E.
Any advice, opinions or guidance would be greatly appreciated. Thanks!
Leo
i had that problem with mine put everything on lose once all the bolts are started then tighten up everything
Sent from my E6810 using Tapatalk
Same issue here. I had to leave the PS motor mount loose to the block and manipulate the crossmember to get the hardware started
Hello Jeepers,
Leo
Leo, glad you got it worked out. Your blog is incredible. Thanks. JBS
