1974 cj5 body bushing!
melvinew2
- Central Ohio
- cj-5 1974 258 t150 4B holley split header , 1979 cj-5 304 t150 stock
Hello I am new here first time CJ5 owner. (I have had yj and Dj5 in the past and still have a dj5) In the past week I picked up 2 CJ5's a 79 with a 304 low miles bad rust no title set for many years in a barn at a farm that the guy passed away in the mid 80's Took a chance (350$ chance) and pulled it home and hooked a gas can to it and it ran amazing on it. Was going to use the engine in my dj5 but the next day i found a ok running 1974 CJ5 258 good frame body is not bad (for being in ohio) some one has put alot of money in to it in its past life aluminum rims, Runck Equipment front and rear bumper, newer soft top and doors, 2.5 inch spring lift, headers, 4B holley, does have drives floor rust and on drivers rocker. clean title. Runs bad and I can tell high miles but I got it off the guy cheap I think (1300$) and drove it the 60 miles home. The last guy that had it has been driving it with a bad valve cover leak so hole engine is covered in oil. The plan is to put the 304 in it once i fix my problem (sure i will need help with that later) So the problem is the frame is good but the body mount on the drives side are shot I need to replace the Floor body supports on the drivers side and front drives pan.(i was going to use Classic Enterprises parts unless you know of a better place?) after that is done I need to replace the body bushing and bolts I was going to use polyurethane I think. I have a few questions about it all. What is the best polyurethane bushing for a 75? Is there a hard where kit or do I just have to buy bolts? How do I get the old bolts out do the run through the floor from the top or use some kind of nut on the Body support? I can find alot of info about 76 and up CJ5 and doing this just not a lot about 75 and down. I don't want to brake the bank just make a good v8 CJ5 cruiser so not trying to go top of the line.
