Still having idle drop, and can't think of anything else, please help.
cuban11182
- CORPUS CHRISTI
- 84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
So I upgraded the last thing that I thought could be the problem. Yesterday I added a DUI ignition. I haven't changed these things chasing the problem, they would've been changed anyway. In any case I'll try my best to explain.
So when the engine is running, the idle will drop about 100 rpm sporadically. When it does it, my voltage drops and then recovers. I thought initially it was my 3 wire alternator, so I replaced that with a higher output powermaster, but it still did it. To verify that it wasn't the alternator I unplugged all 3 wires (still had the pulley attached), and it still did it with the engine running just on battery.
Someone had suggested that the A/C compressor was kicking in (it was un-wired) and I recently replaced that with a Jeepair compressor (still un-wired).
I had found the EGR broken, so I built a plate, then I replaced the intake manifold with an Offenhauser. The carburetors are both new and they were a MC2150 and now a Holly 390. There aren't any vacuum leaks on the intake.
All vacuum lines are new. There are a Limited few: vacuum advance, PCV and brake booster. PCV rattles and mostly holds air when I blow into it, but I'm going to replace anyway.
The exhaust is still stock. I didn't look to see if there is a ground on the exhaust like there is on newer cars, should there be one?
So I'm running out of ideas on what it could be. I've attacked all the wiring under the hood and it's cleaned up and the duct tape that was used to hold things together has been replaced with electrical tape. I know I have a ground under the dash in the signal cluster since when I turn on my signals my tach responds to the indicator, but I couldn't see that being the issue since I had removed the alternator being the culprit.
If anyone has any ideas, I'd greatly appreciate it. Tell me where to look next.
Here is a video. It happens around the 15-16 second mark.
https://www.youtube.com/watch?v=yVcTYMNhQno
