Self Gratification!
CoreyYoungCj577
- Billings,MT
- 1977 cj7 232 inline 6,Dana 20 Tc,T-150 Trans, stock diffs.
So last night was ridiculous, i wanted to get 4 wheel drive back in my 2000 Gmc Sierra so i went to the junk yard and got a electronic transfercase motor for my truck for 50 bucks. Well i didnt start working on it till 7:00 ish so you know a normal hour job became a 5 hour job . I started by removing the skid plate and removing the bolts from the transfercase motor, well i could only get two out all the way which took a very long time because i had very little room to do anything. So then after that i have to move the front drive shaft so i can get the third bolt, well i get the third bolt off and i now have to drop the cross member to get the part out . At this point I was a little angry. So i get everything dropped down and the new one put back in and start bolting it all back up, then i get to the part of the front drive shaft and there is a little clip that goes on each end of ball joint to hold the bottom and top on, well never will i be doing ball joints that clip took me an hour to get on the biggest waste of time! But after everything is all said and done and my truck is back on the road......THE 4 WHEEL DRIVE WORKS GREAT! im thinking fixing the heater next then shocks and minor things!
