RRO OME yj conversion...start with axle shims?
Techlight
- California desert
- 1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
Hi All
So I finally grabbed an OME conversion from RRO and I've been reading tons of install threads and generally gearing up for the install. The lift is supposed to be 3-3.5 total. They get 2.5 out of the springs and about a little over an inch with longer yj shackles front and rear.
My question is about shims to correct the caster. Should I install 4 degree shims from the beginning or install without and have it checked? Is it possible I wont need any with this lift or will I absolutely need some but noone knows what degree until its measured? I'm asking because in my head I figure that if most need them I might as well take a shot in the dark and get lucky as opposed to not putting any in and having to take it apart. A 50/50 shot sounds better lol.
And additionally do I need to shim the rear axle the same or something less since I'm concerned about driveline angles instead of the more important caster on the front?
Any advice is appreciated. Thanks.
Sent from my SM-G950U using Tapatalk
