Performance Camshaft and RPMs question
dbohls
I am new to the forum so please be gentle.
I have a '82 Scrambler. This is how I am set up now. 258 with clifford headers, stock intake, holley 350, hei distributor, performance camshaft from 505 performance, roller rockers, Nv3550 Transmission. The timing is supposed to be way advanced.... like 25. Gear is 3.31.
Is it possible that my camshaft is affecting the way my transmission feels?
Example. 1st gear feels like a granny gear. 5th gear feels like it should be third gear.
Before I had this holley 350 and stock intake, I was sold some snake oil and had this dual weber carb set up from clifford. I could never get it tuned right and it appeared to be washing out my cylinders. So I went back to the original intake and put on this holley carb. I never had this "feeling" with regard to the transmission, when I was running the dual carbs. I had put the performance camshaft in the same time I installed the dual carb setup.
When I bought the jeep, it was stock. I initially replaced the T-5 with the NV-3550. The tranny has always been great. I haven't touched the front and rear gears.
I am racking my brain trying to figure out why the jeep is running like this.
That camshaft can't be affecting my rpm's like this, can it?
Obviously, going back to the original cam is not an easy endeavor.
That's why I am here. Hoping someone can enlighten this wannabe garage mechanic.
