NP435 Conversion.
jafo
Old Time Jeeper
Well, long time coming but I have started on the trans swap on my 79 CJ7. Health issues and life in general has kept me from getting it going but necessity has dictated and required I get it started. Pulled the rear drive shaft, unhooked the speedo cable, went topside to remove the stick shifter and boots. Also got my retractable seat belts installed as well. Ran out if time.
Next steps will be to remove the trans bolts, go under to get the bottom bolts then use my ATV to secure the whole assembly, drop the six skid plate bolts and take the front drive shaft lose and then slide it out and down.
I have taken this trans out a couple times. But I have an NP435 to go in it's place. It has a d300 tranfer case bolted to that. Should be a good setup.
To anyone here who has done this swap. How do you like it and what were some of the issues if any you ran into?
Anyone use the stock skid plate on this swap?
How about reverse light hook ups? What did you do for that?
