Well only the 74 and 73 are mine the 79 is my dad's
. The 73 ran when I got it and I was told that the engine on the 74 ran ,and this is how I wired them. Positive battery cable to one side of the solinoid and starter cable to the the other side.
Run a wire from S on solinoid that goes to + on coil. - on coil goes to points. Negative from battery to block. Then I bridged the blot from the battery to the bolt with starter on the solinoid to get it to fire
. This is the second way.
Neg to chassis ground
Pos to large copper solenoid lug
Starter cable to other large copper solenoid lug
Jump wire from pos batt terminal to + on coil.
Dist pigtail to - on coil. I have not yet rotated the distributor on the 74 ,but I did on the 73 it was
pointing left to the passenger side , so I moved it towards the front . Then I rearanged the plug wires according to the repair manual. I also never removed never of their distributors . The gap on the 73 Is gaped to 0.25 , and I have not messed with the points on the 74 , and this is what I replaced points , the distributor cap , spark plug wires, condensor, coil, solinoid ,rotor ,and the sparkplugs.
