New type of CJ speedo
Torxhead
Always Off-Roading Jeeper
I found this on the net, too rich for me though $500-$700.:
Jeep Cluster - Coming Soon!
I like the inclinometer that tells you when you are about to tip over. Usually my butt pucker tells me that.
good catch. it was set for 8cyl.
then got yelled at for revving the engine at 11pm i'll try the 2 setting tomorrow and see what happens.
i played with it all all settings and everything reads the same for all 4cyl and 6cyl settings - idle shows around 500-600, 4k wot. it's better than when it was set for 8cyl so i can live with it. in the grand scheme of things it doesn't matter and i don't need a tach but if i had known i would have saved the money.
I see on the original speedhut link it says they have a lifetime warranty on the electronics, I think you should call them up and get them to fix your tachometer you paid a lot of money for the gauges and they should work
i did, and they said it is operating as it should. there is also a small problem with the voltage gauge. at rest it reads 12 but while running it reads a constant 15, never a fluctuation from idle to wot. called them up and they had the audacity to accuse my shop of opening the gauge up, which of course didn't happen. got the same old line - we have sold thousands of these gauges and that has never happened before (just like any computer problem - no matter who you call it is always the other companies fault). testing at the battery shows ~14.5. they wanted me to take the dash out and measure at the gauge, so when i have some free time or if something else goes wrong i will tackle it then and we will see how good the "lifetime" warranty is.
both "problems" are inconsequential and nothing that will stop me from driving so i can live with it for a while. i am just happy i know how fast i am going and how much gas i have.
