I am looking at a rebuild project done on a 73 CJ5. The transmission is a 3 speed. I am trying to find out some details on the transfer case. It has 3 levers. Any help determining what they are for would be greatly appreciated.
If it is a 73 it should have a Dana 20 transfer case but your shift levers look to be for a dana 18 with a pto an they were used from 1940 to 1971. Someone could have done a swap. You should crawl under and compare what you have with our transfer case info here -->> https://jeep-cj.com/community/threads/transfer-cases.43552/
I will look at it closer this week. I figure the lever on the left was to engage the 4wd. The middle one would be for the high/low range. I wasn’t sure what the lever on the far right was for.
CJ7 Reman 258, Np435, twin stick 300 dana, Currie 44's both ends with DetroitTrac both ends and chrome moly 35 spline shafts, Maxis Razor 33;s Gps based speedo.
