In the mean time, because these are things you're going to be asked by Troy to check, ensure that it's getting a proper RPM signal. Check your timing. Put a pressure gauge on the fuel supply and make sure you're not way over. If your pump is not the stock pump, or your return line is obstructed, then you could have problems. Fuel gauges are not expensive, and I promise, Troy will ask you what the pressure going to the throttle body is. Might as well be ready.
These are not overly complex systems. Dumping fuel means too much pressure or signal for too much fuel. Read on...
Have you tested to see what disabling the Idle Air Controller does? Pretty sure Troy is going to ask you to do this anyway... At the bottom of page 11 in the installation instructions, you will find in bold "Idle Air Adjustment Instructions". Skip the part that says "before....." and go to the numbered instructions on page 12. What you will be doing is closing, and eliminating the Idle Air Controller from operating until you plug it back in. It's easy to do and this will rule out that the computer is arbitrarily revving your engine by dumping a lot of air (and also fuel) into it.
1. If you have too much fuel (fuel pressure is too high) it should run rich and smoke black. My shade-tree observation suggests this is not the case, as revving real high requires enough air to get there.
2. In my opinion, you're now looking to see why/how/if you're getting too much air. This simple test of turning off the Idle Air Controller (it will be closed and out of the equation until you hook it back up) will see if the system, in the most basic of setups, will at least run reasonably without running away. It SHOULD idle at a reasonable speed without the IAC, assuming that everything else is connected correctly.
3. If it idles correctly then you know a few things and that will help Troy. Notice, that at the top of page 13, they want you to do all of this before calling Howell.
I have a friend that went through one of these systems part for part over the course of a long, long time. He installed a second hand system with no warranty and it ended up being an improperly installed RPM filter (from the factory, many years ago.) Troy will help you get to that diagnosis if you have to. My friends symptom was a surging engine, no matter what he did to solve the problem. This is why I've mentioned ensuring that the system is properly connected to the coil and you've taken proper measures for an aftermarket ignition if you have one. A bad engine speed signal really messes with the computer.
Sorry I've written so much. Don't give up yet, I feel like there are a couple more things you can do to help yourself out, or at least help Troy out when he is able to answer the phone again.
