Horn Problems
Super8mm
- Grapevine, TX
- 1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
I am trying to get my 80 CJ5 ready for a state inspection and I am having a bit of a problem with my horn.
The horn works as I used a jumper from the battery and it ground are OK.
Next I cant find a spot in the fuse box for a fuse there so I am not sure if there is one or maybe it is on the same fuse as something else.
Then I took the horn button off the steering wheel and it is a bit of a mess. It looks like the red circle in the picture gets pushed down to make contact with the part under it? Based on how much rust is in there do I just take out the 3 screws and the nut and lift that part out and clean the rust off?
any input would be appreciated.
