Misc. Help.. Soft Brake pedal after converting from front manual drum brakes to front disc brakes. :/
76cj7chick
Old Time Jeeper
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hey, may I get some ideas why I have a soft brake pedal?
I converted my manual drum brakes to (YJ jeep) power disc brakes in my 1976 CJ7 jeep.
When installing the booster, I did notice the piston rod was slightly longer on the disc brakes than the drums. So I lowered/loosened my pedal to allow the extra length. (bad idea?)
Then, after converting to disc, I now I have soft brakes. I have to pump the pedal before the brakes engage which is scary.
I bled the system 4 plus times (probably more.) I Don't think there is any air. ~But I didn't bench bleed the mc.
And the pedal hardens up after I pump the brakes. (air? Or too long of a piston rod, or wrong pedal?)
I read I may be able adjust (lengthen) the piston rod in the booster slightly to firm up the pedal.
Any Idea On how to fix it?
Hope you're all having a blessed summer! Thanks for the help!
