Help!!!!!!!!!!!! 2003 TJ
My sons 2003 tj has a front end wobble and I mean its bad!!!!. Its ok up to about 45 or 50 then the front end gose CRAZY!!!!. I almost wreaked ,it was that bad . We been thru the front end several times,changed tires,Had the tires re balanced. The tires are 33s .
Had it to the shop several times and they say there is nothing wrong with ball joints,tie rods,ect .
It dose have a 4 inch lift ,brought from rough country .
The only thing I see is that the steering box is leaking . Would a bad steering box cause this problem.
Help!!!!!!
Jeff
Help!!!!!!
Jeff
