Fuel filter install question
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
The 360 is getting close to being finished. If I weren't cleaning up messes making a nice clean install as I go along I'd have it running by now. THe 360 is stock and I will not be getting rid of the emissions controls AND installing a DUI ignition. As most know those HEI distributors are big. Now here's my problem. There are a bunch of components in the vicinity of the stock fuel filter location ... Distributor, water temp sensor, more vacuum stuff than you can deal with, radiator hose, heater hose ........ and I'm sure many other things. Essentially space is at a premium.
The stock fuel filter is placed horizontally ... fuel inlet ... filter body .... outlet and smaller return outlet .... I would like to locate it down by the fuel pump in a vertical position. I know with most filters it really doesn't make a difference, but with the return line I'm not quite sure if the filter would work properly. The vertical position would solve several space issues. Any ideas? Should I just go for it?
Michael
Michael
