Diff Front Axle to Match 8.8 Rear
cloudsrest
What passenger drop front axle would pair best with a Ford Explorer 8.8 rear? The 8.8 is 59.5” wide, and about 60.25” with a c-clip eliminator kit that also gives it 5x5.5. I currently have Scout Dana 44’s and planned to convert the rear to discs and install ARB’s, but was thinking an 8.8 already has discs and is stronger so it would be a better investment. It’s also wider==more stable.
I don’t want the rear to be wider than the front though…usually the front is wider to help with turning, and I want maneuverability and stability. Is there a way to widen the scout front without spacers, like installing outers from a 70’s Ford 1/2 ton Dana 44? Is there a better front axle to swap under it?
