Easy Way to Remove a Yoke Nut.
- Central FL
CJ submitted a new resource:
Easy Way to Remove a Yoke Nut. - Easy Way to Remove a Yoke Nut.
Read more about this resource...
At one time or another - most of us will get to the point where we have to remove the yoke from a differential or transmission. It's pretty easy to break the nut loose if the trans can be put in gear or if the differential is still in the vehicle.
What do you do if you don't have an air wrench available and you have no way of locking that yoke from turning? A quick and simple solution is to put one of your u-bolts back on, slide in a jack handle from a floor jack, snug the nuts holding the...
